Results 1 to 8 of 8
    Jun 2012
    8
    Default Bean bag game boards
    I need to start building 5 sets of bean bag game boards for my daughters fund raiser. I've built a couple for myself and family and stayed with the smaller 2' X 3' size but her group insists on 2' X 4'. It's suggested to use 3/4 plywood in a lot of plans but that makes them heavy. Their plan is to make them collaspible for storage and re-use. The couple I made I just found a 6" diameter something traced it and cut if with a jig saw. It's OK but a little wavy. I was told a router will work well but I'm not sure how to set it up. I know I can buy a 6" hole saw but after these boards I'll have no use and I do own a router. Does anyone have any tips or suggestions on what a good material would be besides 3/4 plywood and cutting out the circles?
    6,062
    Default Re: Bean bag game boards
    6,062
    And it is best to do it in multiple cuts. Make the first turn with the bit barely touching the plywood, then lower the bit about a " at a time to minimize tear out.
    Aug 2012
    10
    i made mine with 1/2" plywood still very sturdy...i also used a jig saw and a 6" round something
    Since you're likely putting a frame around the plywood anyway, 1/2" will be more than sufficient.
    As for cutting the hole, you can rough it out with a jigsaw then clean up the hole with a router or drum sander or as Jack suggests, make a jig for the router and cut the hole.
    Oct 2012
    11
    great advice as always
    Dec 2013
    10
    Haha, this game will be interesting with your advice
