    Apr 2009
    Default Knoty wood bleed through
    I just painted new knoty wood with a water based primer and water based final coat. The knots are bleeding through. Will more coat(s) solve the problem? If not what do you suggest?
    1,987
    Default Re: Knoty wood bleed through
    Try a couple of coats of shellac over the knots, before priming.
    Apr 2009
    158
    yep...agree with the ed...
    I also love Shellac's drying time... It's much better as a primer IMO
