    Apr 2009
    Question How to replace plastic window inserts
    I have these plastic window inserts along all 4 sides of my windows in my house. They have all cracked off and look terrible. I can't find them to replace them and don't know how to get them out. I am not even sure that they are for...it seems like they are there instead of caulking. Our windows are terribly drafty, they even freeze on the inside. I need to replace these things, can you help? Thanks!
    8,065
    Default Re: How to replace plastic window inserts
    Is this the trim strip on the exterior that covers the edge of the glass and blends it into the frame? If so, then trying to identify the window manufacturer would help in finding replacement material. You could also take a sample of your existing trim into a glass shop and see if they could help you locate new material.
    Apr 2009
    Thanks for the reply, the inserts are on the inside of the window.....sealing the glass to the frame, like caulking. The place that did these windows is no longer in business, though I guess I could call the builder and maybe they could help.
    Eden, NC
    285
    Wink Re: How to replace plastic window inserts
    Try calling Stry-Buc industries (PHONE: 800/352/0800)they have parts from all types of windows. They buy parts from companies that have gone out of business. They will be able to help, especially if you know the manufacturer's name.
    Calcats
    Sand Springs, OK
    467
    While I think replacing this piece even if it's just by caulking is a good idea, I would suggest you also caulk outside the windows. Especially around the glass and casement.
    Debby in Oklahoma
