Results 1 to 10 of 10
Thread: upstairs shower
    Jun 2012
    Default upstairs shower
    My up stairs shower does not receive constant hot water. The water will start out cold , go hot, then go cold and back and forth..... What would cause this to happen? This is the only place in the house this happens .... please help
    thank you very much
    1,908
    Default Re: upstairs shower
    You may have a faulty shower valve.
    If it's a single-handle shower, simply replace the cartridge. If after installing the new cartridge hot and cold are reversed, carefully remove the cartridge, rotate it 180 degrees, and reinstall it.
    If it's a 2- or 3-handle shower*, check that the washers on the inside of the stem are not loose. If they are worn, replace them. If the handles are chrome, you may need a special puller to get them off since they are probably corroded on. Then you'll need a crescent wrench to remove the stem.
    (*Some 2- and 3-handle showers use cartridges instead of compression washers on stems.)
    Be sure to shut off the water first.
    Never use a pipe wrench or channel-lock type pliers where a crescent wrench will do. Toothed jaws will absolutely ruin a smooth finish, every time.
    Tennessee
    2,025
    If you are on a well instead of city water, the varying pressure from the well will cause this, it affects upstairs baths more than downstairs.
    Jun 2012
    448 West 19th Street Suite 442 Houston TX 77008
    9
    I'll vouch for this. a family relative of mine also experienced this.
    Jun 2012
    no well and recently changed the valve more help please
    South*East
    1,259
    Quote Originally Posted by dustbunnyacres View Post
    What make faucet do you have? When you installed it you may have gotten something in the faucet if you didn't flush it before putting it in service.
    John
    Jun 2012
    Hello John;
    this was happening before the valve was changed thinking it was the valve, so it is still happening after valve change
    South*East
    1,259
    Hello John;
    In that case there may be a problem with the water heater. What type heater do you have? If it's a tank type there is a dip tube on the cold side that could have failed. That is just a guess not knowing the source of your hot water.
    John
    You are saying that the upstairs shower is the only place where this is happening, and that you replaced the valve and it still does it.
    I still think it's the valve. Did you get the exact replacement valve? did you install it correctly? did you fiddle with the hot limit (if you have it)?
    Yes, what brand is your faucet?
    Jun 2012
    it is a symmons brand faucet and it was installed by a licensed plumber more help please
