Thread: edging walkway
    Jun 2012
    Default edging walkway
    I have a cement walkway that is slanted from one end to the other is a 5 inches. I am putting stone block edging. should I follow the contour of the sidewalk or make the block level?
    8,002
    Default Re: edging walkway
    Depends, do you need a "retaining wall" to boarder whatever is on either side of the walkway, or does the surrounding landscape plane with the walkway?
    If the landscape is higher than the walk, set your boarder to that, if it is in the same plane, set it to the walkway.
