Thread: stuck door knob
    Mar 2012
    Warsaw, IN
    5
    Default stuck door knob
    I have gathered up a few old doors and one has a very lovely glass door knob. I have taken out the screws in the knob but I cannot get it apart. I have tried everything down to a prybar and a flat head screwdriver and all I got was a broken screwdriver and a bent door plate. Its a mortised lock and it works just fine mechanically. Any ideas short of cutting the door up?
    1,906
    Default Re: stuck door knob
    Once you've removed the set screw, just twist the knob counterclockwise. Usually these are on a threaded square shaft.
