Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. #11
    1,387
    Default Re: how many outlets and lights
    Howdy consider having an electrician come and bid the job. Did you pull a permit? I ask as its getting harder to ever sell a home without permitted improvements. Consider getting a books on basic wiring. Good workmanship and code mandates proper spacing and sizing of the lighting,outlets, wire, fasteners, boxes, GFRI recepticles ... a whole host of items to ensure safe construction.
  2. #12
    Shamokin, Pa.
    645
    Quote Originally Posted by NEC View Post
    Could be, I guess. It would mean though that you could put every single receptacle in a home in a home on a single circuit, not limited by other NEC resrictions and meet the requirements of the NEC.
    True but I always use the number eight as a cut off point. Once again no exact reason why using that number.
  3. #13
    gotta love the canadian code eh canuk. wheres old brpw to argue this topic when needed
    Yep ... .....
  4. #14
    May 2009
    Voltage drop calculations are dependent on wire size, voltage, and load. As a general rule of thumb if you run over 100 feet you would go to the next size wire however for incandescent lights the only effect of the voltage drop would be slightly dimmer lights. There is no real code restrictions on length of run or allowable voltage drop.
    I would suggest however that you run 12 ga (20 amp circuit) rather than 14ga for the outlets and have that separate from the lighting circuits. That way if you pop a breaker you won't be completely in the dark.
    Oh, yes their is a NEC code about voltage drop. No more than 3% on branch circuits and no more than 5% on service and branch circuits.
    As a rule. No more than 10 outlets on a circuit. Far as #14 AWG. Use #12. #14 is just control wire. You'll never see a union electrician use #14.
  5. #15
    5,941
    Quote Originally Posted by Union Sparkie View Post
    Actually there is not an NEC code, there is onlt a FPN (fine print note) An FPN is not a code requirement.
  6. #16
    Shamokin, Pa.
    645
    Very few non-union as well
  7. #17
    980
    union does does not denote quality it denotes unity
  8. #18
    Feb 2009
    693
    Jack is 100% correct on the voltage drop issue...... As a union electrician I pulled miles of #14 in residential applications.
    We just stuck to a rule of 8 receptacles on a 15 amp circuit and 10 on a 20. Pretty simple in that 180va is allowed for each receptacle either way.
