Thread: Vapor barrier
    Jun 2012
    19
    Smile Vapor barrier
    Looking at removing the drywall from inside walls that are outside walls and reinsulate with bat type roll insulation. Is it necessary to install a plastic barrier over the insulation?
    7,762
    Default Re: Vapor barrier
    Yes, a barrier must be attached, if the insulation has none.
    BTW, what do you have on the exterior walls? do you a house wrap?
    3,188
    It depends where you live. Here in south Texas, the vapor barrier goes on the outside where the temperatures are warmer. If you are in a climate with winter, then the varop barrier goes on the inside.
