One of my properties is built from a concrete structure. It has tenants in it that complained it was too cold last winter and too expensive to heat. There is currently no insulation in the loft cavity. However, the loft space is above a large concrete plate forming the ceiling below. Will adding insulation help at all as the heat has to get through a thick concrete layer as it is.
And if it will help which would be the best type of insulation.
