    Jun 2012
    Default Salvaging old boards
    I'm trying to do some renovating in an old feed mill my family runs. I'm attempting to tear out some old wooden bins that are no longer useful but I'd like to save the tongue and groove boards that make up the bin walls. Hammer and pry bar is time consuming and often ended up splitting the tongue of the boards. Does anyone know of a better way of going about this?
    7,189
    Default Re: Salvaging old boards
    Can you get behind the boards to clip the nails with a sawzall?
    Jun 2012
    That was actually my next thought. Ive never tried to salvage boards for resale like this so i'm just winging it and didnt know if there was some standard way that people use. I think ill probably try the sawzaw thing.
    1,522
    using a recip to cut the nails holding the boards on works great but can burn up the blade quickly if you dont create a space first for the blade to fit into. what i do is cut wooden wedges first out of scrap 2x4 which i drive between the boards an studs, doing this does less damage to the boards than a prybar does also
    Jun 2012
    Central Missouri
    6
    Depending on what kind of nails were used and what kind of wood, you might be able to drive the nails all the way through the boards with a thin countersink. It works on finish nails anyway.
    Aug 2012
    Northern California
    49
    Quote Originally Posted by toxcrusadr View Post
    That's an interesting approach. I can apply that idea to some things I'm taking apart.
