    Mar 2011
    17
    Default Best way to silicone an already installed sink
    I've got a new granite self rimming composite sink installed.
    I want to be doubly sure the rim is sealed by applying more silicone around the rim. When I use mineral spirits to clean up I am also cleaning up some of the sealant that should stay on the rim.
    What's the best way to apply and/or cleanup the silicone?
    3,176
    Default Re: Best way to silicone an already installed sink
    1- thoroughly clean and dry the area
    2- mask off the rim with blue painters tape, on both sides of the joint
    3- apply less silicone than you think
    4- smooth with your finger
    5- clean off your finger with one square of terlit paper
    6- add more silicone if needed
    7- peel away the tape
    8- dampening your finger with denatured alcohol* smooth the joint
    * do not use paint thinner or turpentine. That will 'eat' at the silicone, can too much can easily make the silicone never cure.
    Mar 2011
    17
    The tape made a huge difference in easy cleanup.
    Thanks
