Results 1 to 10 of 14
    145
    Default portable air conditioning
    Which is better,
    2 exhausts or 1 exhaust out of window.
    Thanks for your help one more time.
    6,080
    Default Re: portable air conditioning
    What ever the unit calls for.
    Jan 2011
    Columbiana, Alabama
    843
    Quote Originally Posted by l.bro View Post
    Which is better,
    I suspect the 2 exhaust units are more efficient.
    Sep 2009
    florida
    598
    Some portable air conditioners have one hot air exhaust hose, and some have two air hoses. One for air intake and one for hot air exhaust. A single-hose portable air conditioner will take air from the room that it is in, cool it, and return most of that air back into the room.
    During this process, a small amount of that air will be used to cool the unit and will be subsequently blown out of the air conditioner's exhaust hose. This creates slightly negative pressure within the room being cooled, as a small amount of air is constantly being removed from the room.
    Note: If this negative pressure is anticipated by drawing unconditioned air into the room from adjacent spaces, then the cooling efficiency is slightly affected.
    Poor exhasting & dirty filters,will allow mold to grow throughout the house.
    Ck the mfg's installation manual and follow the instructions.
    Gizmo
    Hidden Content
    Hidden Content
    Jun 2012
    12
    It depends on the situation, if the environment of that area is normal than 1 exhaust is good enough otherwise you will have to go for 2 exhausts.
    Jun 2012
    I think 1 exhaust is enough in a room. Room temperature is high with 2 exhaust.
    Jul 2012
    Manhattan
    17
    This is easy to handle and manage in your place. It can manage to decrease a good views to have it more place to come up.
    Jan 2011
    Columbiana, Alabama
    843
    Quote Originally Posted by Binanti View Post
    So does the manfacturer say it's OK to try a 2 exh unit w/ just one? No alarms, high humidity or mold?
    Jul 2012
    Manhattan
    17
    2 into 1's generally perform a little better at the high rpm range but lose a little in the mid range torque dept. There are a thousand different opinions on this subject but the dyno seems to support max horse power leaders are usually using a 2 into 1.
    Jul 2012
    LA, CA
    Smile Re: portable air conditioning
    Depends on what you want, If you want just cooling, go with the 2 hose. If you want cooling plus fresh air from adjacent spaces (all of them), go with the 1 hose unit.
