    Jul 2009
    Washington state
    234
    Question Access plumbing from back side?
    I have a one piece alcove tub/surround that we want to have refinished.
    The fixtures and drain trim also need to be replaced. The other side of the wall from the fixtures is an empty wall of another bath. I believe there is a vent in this wall as well. Will a plumber be able to adequately access the valve and pipes from this side?
    Default Re: Access plumbing from back side?
    Most likely yes.
    For the drain, a plumber will need access under the tub.
    And for the valve (faucet) - access from the back.
    Jul 2009
    Washington state
    234
    Thanks for the replies. The drain is accessible from the basement, so I think that will be OK.
