    May 2012
    Default Mold under floating wood floor - with photos
    Hello,
    About 2 1/2 weeks ago had water damage to our lower level, which had a floating wood floor over a concrete slab.
    We have started to take up the wood and pad (it is unsalvageable, we are discarding it all), but there is fuzzy mold all over the bottom of the wood, and on the bottom of the pad as well (white/green/creme colored mold, as well as darker mold on the wood).
    My question is, is there a safe way I can remove this myself, or do I need to contact a mold removal team to deal with this, like Servepro? We're look at probably 400sf.
    I have attached some photos so you can see what the mold looks like. Thanks for any advice.
    Attached Files Attached Files
    5,824
    Default Re: Mold under floating wood floor - with photos
    First let me say that not all mold posses a health hazard. Cleaning with a bleach solution, then thoroughly dying should take care of the existing mold. Mold only grows where moisture is present.
