    Feb 2012
    Souderton, PA.
    15
    Default Laminate Flooring
    Does anyone know if there is any truth that you should lay your laminate flooring in the opposite direction of the joists? I was just told today that laying them in the direction of the joists can cause squeaking and possible separation down the road.
    7,715
    Default Re: Laminate Flooring
    That's true, even when you have a sufloor, which is a must.
    Feb 2012
    Souderton, PA.
    15
    So I should go the opposite direction of the joists
    7,715
    Yes. Let's call it perpendicular to the joists. This way each plank of laminate will be resting on the joists and the subfloor.
    7,908
    Yes, this is the way to go whenever possible.
