    May 2012
    Default Shower water spout too far from the wall
    We just moved into a house. The water spout in one of the showers sticks out from the shower wall by about 1/4". The caulk is gone, but I think the gap is too big for just caulk. How do I move it back against the shower wall?
    7,343
    Default Re: Shower water spout too far from the wall
    Question: Do you mean the tub spout?
    In most cases, the spout goes on a nipple that extends from the faucet out. In your case the nipple may be a bit too long. Unscrew it and replace with a shorter one.
    Another question: can the spout move/rock back and forth?
    May 2012
    Yes it is the water spout for the tub.
    It doesn't move either side to side, but if you push it really hard you can push it towards the wall.
    3,120
    is the rest of the plumbing loose?
    1,794
    Some tub spouts are mounted to copper pipe rather than being threaded on. There will be a setscrew accessed via a hole under the spout next to the wall. You will need an allen wrench for this.
    You may not be able to push the spout all the way on. In this case, you will need to remove a portion of the copper pipe using a tubing cutter. There is some degree of forgiveness in the spout, so you should be able to cut about 3/8" off -- but I can't be certain of that.
    Sep 2009
    florida
    598
    Thumbs up......I just had to do this myself for a friend.....if the set screw isnt on the bottom turn the spout it may of been installed up. You will be able to see it through the knotch out on the underside of the spout.....
    Gizmo
    Hidden Content
    Hidden Content
