    Mar 2011
    Default Pavers on top of Concrete Patio
    Can I put a sand bed over my concrete patio and then lay pavers on top of the sand bed? The concrete patio is slightly below the surrounding grade. I am concerned that the sand might wash away under the pavers. Should I remove the concrete patio first?
    Default Re: Pavers on top of Concrete Patio
    Yes you can. Install some sort of edging around the patio to: 1. prevent the pavers from wandering, 2. prevent the sand from eroding.
    Sep 2009
    florida
    598
    Set the outside band of pavers in mud,(mortor or thinset) to eliminate any movement. You will always be loosing some sand....nature of the beast.... especially if the slab has any pitch to it.......
    Gizmo
    Hidden Content
    Hidden Content
