    20
    Default stairway handrail
    i want to replace it and it`s not the same distance,from rail to step 2"diff.from top to bottom. anyone know if there is a certain distance i should be aware of thnx
    20
    Default Re: stairway handrail
    if you measure from the tread to rail on the top step then measure from tread to rail on the bottom step, it`s 2 inches higher at the bottom. i`m sure that`s not right and thank you.
