Thread: Wainscotting
    May 2012
    Default Wainscotting
    I want to renovate my living room, planning a full gut to the studs. I'd like to install recessed panels around the room but how do you determine the size of the boxes? With things like doors, windows, fireplaces in the way it seems impossible to find a single uniform sized box with even spacing for the whole room.
    6,936
    Default Re: Wainscotting
    There is no "standard" size, so you can do whatever fits the space best. You could even make a cardboard template or two of different sizes to see which you like the best.
    When it comes time to install them, choose one single size to work with. You can start your layout in the center of the wall and work your way to the corners so that the panels have even reveals on each end, or you can start in one corner and work your way around the room, breaking partial panels around corners. I personally like to lay out from the center of the wall.
