Results 1 to 10 of 11
Thread: Diverter?
    Apr 2012
    10
    Default Diverter?
    I have a kitchen sink with a side sprayer. When I use the sprayer, the water in the faucet does not stop running. Is the part I need a diverter? How is it installed?
    South*East
    1,227
    Default Re: Diverter?
    It is a problem with the diverter. There in different locations on different faucets. If you can tell me what faucet you have I can help you get the correct one and give you instructions on how to replace it.
    John
    7,235
    John
    Where the heck can you get a diverter? I need to replace mine and nobody has it. All I can tell you is that it's a Delta that's about 12 years old, single lever with side mount hose.
    Apr 2012
    10
    I have a Kohler Double Handle Kitchen faucet, K-16109-4A.
    South*East
    1,227
    Most plumbing supply houses should have them. You may be able to get one at the big box store. They may not know what they look like. Here is the one you need. To install it you have to remove the spout and it's in the front under the spout. Just pull the old one out and install the new one.
    http://www.lowes.com/pd_21760-72981-...Id=3192813&sit
    John
    Apr 2012
    10
    I get an error when I go to that link. Can you give me the info so I can Google it?
    Apr 2012
    10
    Hmm. The link changed. I can now see a DELTA Diverter Assembly. I can use that for my Kohler faucet?
    South*East
    1,227
    Quote Originally Posted by emst View Post
    Here is a PDF file showing your faucet. Go to page 14 that shows the break down of your faucet. The diverter is part # 75878.
    http://www.us.kohler.com/webassets/k.../1130185_2.pdf
    John
    Apr 2012
    10
    Thanks. I'm a 64-yr-old lady--do you remove the spout (like the Delta) and is the part inside?
    South*East
    1,227
    Yes you do remove the spout. I would also replace the O rings at the same time you replace the diverter. Just pay attention to the order in which the parts come out.
    John
