Results 1 to 10 of 11
    May 2012
    Default 3/8 drywall and 1/4 paneling
    My house was built in the 60's. The interior walls are unfinished 3/8 drywall with 1/4 paneling over top. I want to remove the paneling. What is the bset way to finsih the walls.
    Can I tape and mud the 3/8 or do I need to strip this out and replace with 5/8 material. Thanks
    3,188
    Default Re: 3/8 drywall and 1/4 paneling
    3/8" won't meet the fire code round these parts. You'd need 1/2". Check with your local inspector or building dept. be 100% sure it isn't 1/2" before going any further. 3/8" is pretty rare stuff.
    When removing the drywall, this is a perfect time to change / upgrade any wiring, plumbing, and insulation. Also check for termites and other wee critters.
    May 2012
    Is it possible to install 3/8" drywall over existing old plaster?
    7,762
    Quote Originally Posted by richibieltz View Post
    Yes. Keep in mind that the new drywall will follow what's behind it.
    Also, you'll need to use longer screws driven into the studs.
    3,188
    Or use a good adhesive such as PL Premium
    May 2012
    Thank you for reply; I will use PL Premium adhesive around the drywall edges and 3" screws.
    South*East
    1,253
    Your looking for trouble with 3" screws. There is a good chance with screws that long you can hit wires and possibly water or waste lines in the wall.
    John
    7,762
    Quote Originally Posted by johnjh2o View Post
    John
    Absolutely, when I suggested you use "longer screws" I didn't mean 3"...Just yesterday I saw a situation where somebody installed shelves using long screw and one of them pierced through an ABS drain pipe.
    If you add 3/8" to the original plaster, all you need to do is add that much to the regular drywall screws (reg size is 1-1/4").
    3,188
    2" course threaded screws and just a few dabs of PL which then are spread thin with a trowel
    Sep 2009
    florida
    598
    You can go over it with 3/8 or 1/4"........
    Gizmo
    Hidden Content
    Hidden Content
