Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. #11
    Columbiana, Alabama
    691
    Default Re: Inline GFCI on AFCI circuit
    You're very wise to add GFCI protection to the circuits close to water where contact resistance is very low.
    If you can locate the bedroom receptacle which feeds the bath fan & lights simply replace it with a GFCI receptacle and you should be fine.
    I've discussed this with an AHJ,EE, CMP member friend and we do it all the time.
    Maurice Turgeon, http://thesemi-retiredelectrician.com
  2. #12
    6,305
    If you added a circuit dedicated to the bathroom, you don't need AFCI, but you need a GFCI near the water source.
  3. #13
    Columbiana, Alabama
    691
    I agree DJ but a funny label is now placed on some "standard" GFCI receptacles. They read something like "not to be used in wet or damp locations". I thought like you.. that's why we install them...because the location is either wet or damp
    I think they're just trying to say... outside we now have to use the "weather resistant" type.
  4. #14
    Aug 2011
    65
    The AFCI trips if ground leakage exceeds 30 MA a GFCI if ground leakage exceeds 6 MA, either one is more than enough personal protection because it takes 500 MA to be deadly.
    Whoever told you it takes 500mA to be deadly is totally wrong.
  5. #15
    5,774
    Quote Originally Posted by brrichter View Post
    Oops, sorry got and extra 0 in that post, it should have said 50 MA.
  6. #16
    1,905
    Quote Originally Posted by The Semi-Retired Electric View Post
    I don't have a clue what it takes to kill someone and I suspect there aren't many volunteers to conduct experiments with...
    Put me on the "Do Not Call" list for that, Maurice
    Great knowledge and advice from you as always!
