Thread: Removing Grout
    May 2012
    Default Removing Grout
    I installed tile the entryway into my home but did not do a sufficient job of removing all of the grout from the tiles and the grout dried on the tiles. Is there any way to remove this grout from the tiles? The tiles themselves are rough so I cannot sc**** it off without damaging the tile.
    3,188
    Default Re: Removing Grout
    First try straight white vinegar and a scrub brush.
    If that fails go to Home Burrito and get some sulfamic acid crystals which get mixed with warm water before use with the same scrub brush.
    DO NOT use muriatic acid.
    Jan 2009
    Needham, MA
    559
    any store that sells tile and related materials sells a "grout and haze" remover. it's a liquid that dissolves the grout and haze on the tile.
    3,188
    The grout haze remover is often Phosphoric acid which isn't as effective as the much cheaper white vinegar and sulfamic acid.
