Results 1 to 8 of 8
Thread: Dimmer Switch
    Feb 2012
    Souderton, PA.
    15
    Default Dimmer Switch
    Can you install a dimmer switch for recessed lights on a switch that is controlled by and outlet.
    Jan 2009
    Needham, MA
    559
    Default Re: Dimmer Switch
    sure you can
    Feb 2012
    Souderton, PA.
    15
    Does it need to be a certain type since it is being controlled by a wall outlet or will any dimmer work.
    7,762
    The type of dimmer has to do with the type of bulbs you are using. Ger the dimmer that meets your bulbs.
    Feb 2012
    Souderton, PA.
    15
    Was going to pick up a 600 Watt Single Pole Dimmer, do you think that would handle things.
    7,762
    Quote Originally Posted by redhillbob View Post
    That depends on your total wattage use.
    Columbiana, Alabama
    843
    If power will be coming from a completely switched outlet it would only be capable of dimming/controlling the light if the outlet switch is "on".
    But, if 1/2 of the duplex receptacle is always on, if it is wired per Code, it should work fine, even if the receptacle switch is "off".
    Since the power is coming from a receptacle,which must have a neutral, you can purchase a dimmer that requires a neutral, and is capable of controlling a CFL, LED or incandescent lamp.
    If you want to control a CFL, be sure the dimmer & CFL are capable of dimming...some are not.
    Maurice Turgeon, http://thesemi-retiredelectrician.com
    240
    To determine the dimmer wattage required, add up the MAX wattage for each fixture.
    If 4 recessed lights have a max 100watt and you are only using 60 watt bulbs, that dimmer must be rated at more than 400watts so that 600 watt dimmer would be fine. You can usually find the max wattage on the inside of the can by removing the trim from the recessed light. Manufacturers also sometimes include derating factors for multiple dimmers or box volume.
