Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. #11
    7,762
    Default Re: Problem with door hinges
    Some of the items you guys are recommending are plain funny...
    I'll use food items for food, and WD 40, liquid wrench (or any lubricant I have) for the hinges. A drop or two is all we need here...
  2. #12
    Apr 2012
    Smile Re: Problem with door hinges
    Hey, I love the discussion and all the ideas (some of which are just a bit unusual) and I've tried silicon spray which works for awhile but fades. I will try the WD-40 and some 3-in-1 but I am also looking for other ideas about cleaning up the graphite. Has anyone tried a tack cloth?
  3. #13
    7,968
    A tack cloth will work if it is a dry dust, unfortunately, hinge dust could be graphite, could just be metal powder, probably contains oil of some sort, which means a tack cloth isn't going to cut it. The lighter fluid I suggested is probably your best bet and it shouldn't hurt the paint, but do test it first.
    Typically, I use a drop or two of 3-in-1 oil on hinges because it is the easiest to apply. If you use WD-40 then you will need a rag held behind the hinge to catch the over-spray and dribbles.
  4. #14
    1,375
    I just a couple of weeks ago switched out a houseful of builder's hardware for nicer stuff (Baldwin and Emtek) and used simple windex to get the "graphite" off the white woodwork.
    Casey
  5. #15
    May 2012
    12
    I Tried Peanut Butter!
  6. #16
    2,686
    I prefer PAM cooking spray to mayonnaise for hinges as it applies easier and the buttery smell is kindah nice.
    Hey- does this make HoustonRemodeler a "PAMMER" on this forum?
    Sorry guy but I couldn't resist the pun! I'll go away now...
