    Feb 2012
    Souderton, PA.
    15
    Default Laminate Flooring
    Was wondering if anyone has ever used and underlayment for their laminate flooring that already has and underlayment attached to the existing board to raise the height of the flooring to meet a connecting tile floor. I am trying to find a way to raise the floor a bit higher to be as level with the tile floor as possible.
    7,635
    Default Re: Laminate Flooring
    How much higher do you need to go?
    1,522
    its done everyday in new construction and renovations so to create a even transition between two different flooring types so that a reducer isnt required.. just figure out the difference between the laminate then buy plywood that thickness and bang it down
    Apr 2012
    I agree with the advice the krik, but if you can share some picture with us; we will able to advice a right solution for this problem.
    Sep 2009
    florida
    598
    It depends on what your definition is for raise the floor a (bit) higher....
    Gizmo
    Hidden Content
    Hidden Content
    1,522
    you dont need pictures to figure it out.. just simple math
    where the laminate will meet the tile simply measure the height of the tile off the subfloor where the laminate will be.. if your tile is 7/8" higher than the subfloor where the laminate will be simply subtract the thickness of the laminate flooring and this will give you the thickness of underlay you need.. i.e 7/16" laminate will require laying 7/16" underaly. or if your putting down 3/8" laminate you need 1/2" underlay
