Thread: Chimney hose?
    Apr 2012
    216
    Question Chimney hose?
    Last year I had the roof repaired and I went up to look at it the other day and noticed that they removed the chimney cap that was on there and put on a smaller one that has a silver hose going down inside the chimney. Why would they possibly do this? As far as I know the only thing the chimney does is hook up to the water heater and vent CO2. What's the purpose of the silver hose?
    6,114
    Default Re: Chimney hose?
    It's called a chimney liner. More efficient appliances often need them to reduce the size to get proper draft and they are necessary to prevent deterioration of masonary chimneys.
    Apr 2012
    216
    Post Re: Chimney hose?
    THANK YOU Jack, I was just reading about them
    Funny how they are so important and yet no one at Home Depot knew anything about them
    6,114
    Always be careful of advice you get from HD.
