    Apr 2012
    216
    Post Which adhesive to fix chimney flashing?
    I am in the process of running some new wiring and had to remove some old flashing around the chimney in the basement. They used a pinkish adhesive (see below) that was brittle when I took it off. I'll need to replace this when I'm done wiring, but what is that adhesive called or do I use?
    3,201
    Default Re: Which adhesive to fix chimney flashing?
    The only reason for flashing under the roof / house would be to keep rodents / insects out. Use the expanding foam in a can. Or use screws to hold the sheet metal back up into place.
    1,522
    that caulking looks like "fire caulk" its a fire rated silicone
    Apr 2012
    216
    Question Re: Which adhesive to fix chimney flashing?
    It was very brittle. Can silicone get brittle?
