Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. #11
    Mar 2013
    Default Re: Leaking metal barn roof nail gaskets
    In reply to the leakey barn roof i have the same problem and i am going to try to break off the head and i will be able to put the new screw real close to the nail and this should cover the hole if not i can use a little silocone before i put in the screw hope it works Ron
  2. #12
    1,904
    Quote Originally Posted by ronpayne View Post
    Don't use silicone caulk - it won't last. Use butyl rubber caulk with a UV inhibitor.
