    Apr 2012
    Default bath shower pours when in use
    Upstrairs when the shower is in use it POURS down in my own bathroom.
    It seems to be coming from a pipe somewhere . We opened the sealing and i see the beams - where the bath sits but i cant see the shower line - it is in the wall But i collected 4 cups of water - warm water - what could be the problem ? help !!!
    7,337
    Default Re: bath shower pours when in use
    If the leak only happens when you use the shower, the leak is most likely in the drain. Expose more of the framing to pin point the exact loaction of the leak, and fix it.
    A leak in the hot water supply line would have resulted in a continuous leak, which is not the case here.
    Apr 2012
    so where is this drain you are talking about ? i did a test and when we take a bath no leak only when shower is in use...
    thanks
    7,337
    In light of the new information you provided:
    If the leak happens ONLY when you use the shower, it could be coming from the shower diverter or the shower pipe/connection.
    If you have access from the back of the bathroom, you'll need to cut the drywall to be able to spot the leak.
