Results 1 to 8 of 8
    Oct 2011
    20
    Default NO thinset between Hardibacker and subfloor
    My contractor told me that despite hardibacker installation requirements he did not need to put thinset between the subfloor and hardibacker as long as he nailed the hardibacker down well.
    Should I have him take it up and put the thinset down?
    7,344
    Default Re: NO thinset between Hardibacker and subfloor
    You contractor is correct, providing he placed a 6 mm moisture barrier between the two.
    I'd use screws instead of nails and follow the screw schedule precisely.
    You use thinset to set the porcelain tiles on the hardibackers.
    Oct 2011
    20
    No moisture barrier was used between the two.
    He did not use a vapor barrier underneath the tub surround hardibacker he put up as well. The wall is interior with no insulation.
    Thank you!
    3,120
    I will politely disagree with my colleague. TCNA guide lines are very clear as well as manufacturer instructions. The board was installed incorrectly and should be removed.
    The sheet vinyl or plastic underneath can do more damage than good.
    7,344
    Thanks Houston for correcting me...I was thinkind a different scenario!
    1,902
    In a This Old House magazine issue a couple of years ago, the late Joe Ferrante recommended using construction adhesive instead of thinset under the cement backer board on the floors. I followed this advice and it has worked for me. I did not use a vapor barrier on the floor except in the shower pan, but I did use tar paper behind the hardi board on the walls. BTW, I did not use the hardi board brand of cement backer board on the floors but I did on the walls.
    3,120
    When used on the walls sheet plastic or tap paper can be used as a moisture barrier behind ceement board. It should be overlapping the tub flange. The ceement board should almost set on the top of the tub flange, firmly against the studs and not sloped out at the bottom from overlapping the flange.
    1,387
    Howdy go to the John Hardi web page an look at the best practices ( more information the then instruction section my opinion0 an the instillation instruction pages- very informative.
