    Mar 2012
    Default Reaching High Ceilings
    I have need to do work around skylights located in vaulted ceilings, and also windows around the same height.
    What is the best tool to reach this height? What type/size ladder? Also, is it possible to use a aerial lift for this?
    Thanks
    7,235
    Default Re: Reaching High Ceilings
    Depends, what is the access to the area like and what is in the area itself?
    Lifts tend to be larger than what will fit inside a house, they are also very heavy which can cause problems with the floor. A lift would be perfect for a warehouse situation.
    Inside a house, especially a furnished one, scaffold would be the better choice.
    Maryland
    1,714
    A good tall step ladder can be handy. Just get one tall enough so you don't have to use the last step.
    For a large or involved job, scaffolding might be best.
