    Mar 2012
    Default ceramic wall & floor tile
    What should be the space between the wall and floor tile in a shower? No space? 1/8" space?
    Tennessee
    1,985
    Default Re: ceramic wall & floor tile
    You use the same spacing as you do between the tiles, but you use a special caulk on this seam. The caulk is flexible and resembles grout. If you grout this seam, the wall tiles will crack. This caulk is also used on all wall corner seams for the same reason.
    Mar 2012
    12
    The same spacing as you do between the tiles.
