    Jan 2012
    Default cleaning toilet water tank
    what product works well to clean the toilet water tank someone mentioned CASCADE detergent...any suggestions
    Feb 2012
    Default Re: cleaning toilet water tank
    I wouldn't recommend any product to clean the toilet water tank any chemical compound including the chlorine in city drinking supply damages the fill valve and flapper and rubber components if you use any chemicals you will damage parts I recommend using a shop vac and sucking out debri first shut off water then wipe down the inside if you insist on cleaning it but no chemicals! it will even say on fill valves and flappers warranty will be void if a bleach tab or cleaning tab is used same thing with cleaners.
    Ben & Munson Mech Plumbing
    Lehi, UT 84043
    (801) 960-1766 ‎
