Thread: hot water odor
    Mar 2012
    Default hot water odor
    I have a problem with sulphur smell from hot water heater(odor in hot water only). plan to change anode but have seen advice to use chlorine to disinfect heater as well. is this a good idea or will it cause more problems? what is best way to do this if its ok?i am on a well and water has been tested for sulphur levels(levels are low) so i assume odor is from bacteria build up.
    7,349
    Default Re: hot water odor
    Yes, change the anode, but you have to treat the well, as well, so this won't happen again so quickly.
    3,121
    Do a web search on using ordinary household bleach to rid the tank of the sulphur odor. It works well. Also change the anode.
