Results 1 to 10 of 13
    Apr 2008
    26
    Default Insulating void space, flat roof with balloon structure
    I am looking for some help. I am residing in Southeastern PA and I reside in a 60 year old end unit. It's a brick structure with balloon framing. I need to insulate the "attic" space. It's approximately 400 +/- square feet. I can only assume that blow in insulation is preferred only because it had been used prior, but it's old and settling and missing in areas. Do I blow it in a fill as much of the space as possible or do it just fill the ceiling joist area. Also do I need to be careful not to cover the wall stud spaces as to let the air circulate or can I/should i fill that space too?
    Thanks to all in advance
    Tennessee
    1,791
    Default Re: Insulating void space, flat roof with balloon structure
    Is there an attic? Are there separate ceiling joists and rafters? If there is an "attic", how tall is it?
    If the unit is 60 years old, that means it would have been built around 1952. Balloon framing was no longer being used by that time. Whether it is balloon framing or not, you can fill the wall spaces with insulation, but I doubt it will settle very far. Building codes usually required fire blocks by then.
    Apr 2008
    26
    the ceiling joists are 2x4 and the roof joists are 2x10, I believe. The highest end is about 12" space, not including the ceiling and roof joist height and the low end, the roof joist sit right on the ceiling joist. No keep in mind I'm not a contractor, I can only describe what I think I see. My verbiage may nit be correct. On one my concerns is having snow and ice form on the roof if I do something wrong when blowing this stuff in. I had several estimates and it's just insanely higher than the DIY price from my local big box and not one estimate comes with a warranty.
    1,387
    Howdy this is a great time to get some estimates. A closed cell foam might give you the best for the $ with limited space and then have cellulose blown in on top of it. The out side walls have a void at the top? What do the roof joists rest on?. You might want to add insulation to the walls but with brick issues with it being able to wick out water or not so again a great time to have a contractor actually several come look an advise you. At the least consider putting some Roxal, it does not give off as many itchy fibers as some competitors rock wool, insulation over the wall voids- it has a great fire rating and cuts like bat fiberglass. Adding rock wool or a 2 by4 or 6 on top of the wall void is to stop chimneying or any fire gas/flame. Moreover. to stop convection of air that sucks the heat or cool out of the house with it depending on the time of year.
    Tennessee
    1,791
    This sounds like it will be a very difficult job to do. It is hard to give advice because I don't know how the "attic" is ventilated. At the very least, you want to fill at least a couple of inches above the ceiling joists. Exposed ceiling joists will act like radiator fins sucking the heat out of the room below.
    You do not want to insulate all the way to the underside of the roof, but you might be able to insulate up into the roof rafters a little. It depends on the ventilation system.
    Does the roof overhang the wall? How much? Are there vents in the overhang? Is your unit a two (or more) story?
    Apr 2008
    26
    No, it does not over hang. It does have a Mansore roof on two sides. The back on the house has two vents built into the wall, the same dimensions of a brick. I also has a TPO roof installed and the rear of the house has a standard roof vent and the front has a fin style vent that spins when its breezy.
    Tennessee
    1,791
    Quote Originally Posted by JTNuck View Post
    Did you mean Mansard roof? I am not familiar with a Mansore roof. A Mansard roof has to go all the way around the house, not just on two sides. Could you have a Gambrel roof instead? That would be on two sides only.
    The back of the house and the rear of the house, are they not the same thing? I am not familiar with TPO roof.
    Apr 2008
    26
    I suppose it's a mansard roof. It goes across the front and side, as I said it's a end row. Their is also a parting wall between the neighbor and myself. The TOP membrane is a loose lying membrane that is mechanically fastened at he seems. I don't know a lot about it the roofer talked me into it with a 20 year warranty and being maintenance free. Seeing I need a 32 foot ladder to get on my roof I thought it was the best option.
    Apr 2008
    26
    Very sorry, I meant to type TPO membrane nit TOP membrane
    Tennessee
    1,791
    I'm still trying to get a picture in my mind. You have a Mansard facade on the front and end walls for the second story of the unit. The rear does not have a Mansard facade. Is there an eave on the back side? If so, are there any vents in the eave? If no eave, then there should be a facia board and maybe it would have vents.
    Now for the roof. Does it have a ridge in the center or does it slope from the front to the rear with no ridge in it? The standard roof vent in the rear, is that just a pipe sticking straight up, 3 to 4" in diameter? If so, that is the DWV (drain waste vent) and is not part of the attic ventilation.
