    Mar 2012
    Default Standing water in grass parking stall
    I have a spot in my back yard for extra parking. However, every Spring after the snow melts it turns into a large 3 inch deep puddle. The spot is probably 10'x10'. What are some ideas to help prevent the standing water so we can use it? It does not have to be a fancy and expensive solution because the problem only lasts for a few weeks in the Spring and it is only used occasionally. My initial thought was to put down some gravel. But what kind of gravel?
    Default Re: Standing water in grass parking stall
    If you are certain that the sitting water is from melting snow, you are having a grading issue. That 10x10 area is a low spot.
    Re-grade, or build the area up and the water will go away. Use dirt for that. You can top it with some 3/4" gravel, which even comes in different colors.
    Mar 2012
    So 3/4 inch gravel, have you heard of anyone snowblowing over that? I'm wondering if I use 3/4 inch rough gravel if the snowblower will throw a bunch of rocks next year or if it will be OK because it will have settled down enough.
    Feb 2012
    18
    you could re grade, might take some money.. Or you could put a french drain or something simple like that in. You can make a french drain with a shovel, hay bail concrete blocks and rocks. Look it up on google there are lots of ways to do it
    Kendall Roof and Exterior Cleaning
    Hidden Content
    Hidden Content
    Keyport, NJ
    36
    A snowblower will pick up the rocks and throw them.
