Results 1 to 10 of 10
    Jul 2008
    49
    Default Why does glass replacement need to installed from exterior
    Hi All,
    Just curious I was told glass replacement should always be installed from the exterior otherwise it will probably leak....Is this a true statement...I don't understand why it would leak if glass is installed from the interior side.
    7,762
    Default Re: Why does glass replacement need to installed from exterior
    Depending on the type of window you have, in some windows you replace the glass from the outside, in others the window frame has to be disassembled.
    Can you send a photo?
    7,966
    Imagine that you are on a submarine. If the glass was installed from the inside the pressure of the water would push the glass away from the seal, causing it to leak. For this reason, view portals are installed from the outside, as pressure increases, the glass is forced deeper and harder into the seal, preventing leaks. The same, in effect, happens to windows on a house.
    6,015
    1-The wood mutins provides a point for leaks if they were on the outside,even if the glass is pressed into a bed of glazing an 2-it is more aesthetic on the inside with mutins rather than glazing.
    Jul 2008
    49
    Hi . A. SPRUCE
    I understand the obvious reason in the case for a submarine. However, for a house why would the pressure be greater outside?
    Tony C
    7,762
    What you are trying to avoid is moisture coming in. And glass mounted on the exterior of the window with glazing material, will stop the water better. Done correctly, it will stop all moisture.
    7,966
    Quote Originally Posted by tonyc56 View Post
    Hi . A. SPRUCE
    Tony C
    Wind and driving rain.
    Jul 2008
    49
    Makes perfect sense...
    1,929
    To re-inforce Spruce's observations, the better sliding patio doors have the movable panel on the outside. When the wind blows against it, the weather seals are compressed even tighter.
    1,522
    for the same reason we install outswing entry doors as much as possible. im on the coast and were starting to see more and more hurricanes... heavy winds can push on a inswing door which can allow water in very easily.. if its an outswing the wind pushes the door into the weatherstripping creating a even tighter seal
