    Mar 2012
    Default double vanity, one drain
    I have a very wide vanity with a sink on one side. I would like install a second sink, and tie it into the other drain. Both sinks would use the same drain. Is this a bad idea?
    7,341
    Default Re: double vanity, one drain
    It's done frequently in master bathrooms. If you have a 2" drain in the wall, a second sink will not be such a big problem.
    Feb 2012
    92
    Shouldn't be a big deal but you need to find out how many fixtures our on that line already local and federal codes only lows a maximum fixtures per pipe so if its only that one sink your fine but if it ties into a kitchen below or whatever you may have to many fixtures on that drain already.
    Thee Punctual Plumber
    342 N 100 E, Spanish Fork, UT 84660
    (801) 960-1755 ‎
