Results 1 to 10 of 12
    Mar 2012
    Default closet motion sensor
    Installed a motion sensor light in the closet, but becaise you are behid the sensor when you open the door, it doesn't sense you and doesn't come on. Help!
    7,762
    Default Re: closet motion sensor
    What's wrong with the usual wall switch as you open the closet?
    In a small closet without a light, you can install a simple battery operated touch dome light. Cheap and useful alternative.
    Mar 2012
    The switch is on the wrong side of the door.oposite side from door opening. There is a light , but you open the door, remember the light and you have to close the door to flip the switch. Inconvenient
    and annoying.
    8,002
    Install a pressure switch on the door, that way when the door is opened the light automatically comes on.
    You could relocate the motion sensor to a more suitable location and then just extend the wires back to the lamp base using wire mold or conduit.
    Jan 2011
    Columbiana, Alabama
    843
    A mirror on the back wall?
    8,002
    I want to change my earlier answer.
    Rather than screwing around with motion sensors and rewiring everything, why not just put the light switch inside the closet? Simply install a cut-in box behind the existing switch, then move the switch and wires to the new location. When you're done, put a blank cover over the abandoned box. Now you can simply open the door turn on the switch and have light.
    Short of that, I'd go with my original suggestion of a pressure switch that automatically turns on the light when the door is opened. Simple switch, simple installation.
