Results 1 to 10 of 12
    Jun 2011
    5
    Default Can someone explain what polyurethane is for?
    Can someone explain to me what polyurethane is for?(not sure that's what it's called or how it's spelled. sorry)
    I stained my living room floor of rough/rustic pine planks with Minwax floor stain. Now the Minwax says it "seals" right on the label. But the guy at the store said that I needed to 'seal' the floor with a polyurethane after staining. So now I am confused. Does the Minwax actual seal the wood? What is the purpose of applying a poly on it.
    Default Re: Can someone explain what polyurethane is for?
    First and foremost, Minwax makes great stains, but their poly and other top coats are absolute garbage!!!!
    Polyurethane is a clear finish that has replaced lacquer and shellac because of it's more environmentally friendly. There are different types/grades of poly, make sure you're using one rated for floor use before applying or you're going to have a huge mess on your hands when the coating fails.
    Not sure what your stain is capable of without knowing more about it. Some stain products are a stain and top coat finish all in one. These are a poor choice for most projects, particularly a floor because the stain is held within the top coat finish like a paint, rather than a penetrating stain. What is the exact brand and product description of the stain you used?
    Jun 2011
    5
    The can says "Minwax Floor Stain" and "Stains, Penetrates, and Seals"
    I still don't know if I should leave the floor with just the stain and skip the polyurethane, or do floors absolutely have to have poly on it.
    1,522
    definitely put 3 or 4 coats of polyeurathane on the floor, the stain does seal it in a way but its there to give the wood color. the poly is what seals the wood from moisture and gives it extra durability as the finish coat will scratch before the wood itself does. if you get a scratch you can buff the finish
    1,386
    If you are finishing a pine bookshelf or a cherry desk, then no further sealer is needed before the varnish step. Floors are a different animal. If your topcoat demands a particular sealer, use it; it's all about the bond between the wood and the finish. Sometimes a very hard-wearing topcoat makes a bad first coat onto the wood, and really needs its primer/sealer to grip.
    On an oak floor, you need the sealer coat to get a good start on filling in the very open grain. Varnish alone is very slow to fill oak's porous surface.
    Casey
    Quote Originally Posted by FrenchGirl View Post
    As I said in my first post, Minwax top coat products are utter garbage, so I can assure you that you will need a proper polyurethane top coat. You will want to use a coating that is specifically rated for flooring or you will be wasting both your time and your money. I have never refinished a floor, so I cannot recommend a specific brand of poly to use.
    Keyport, NJ
    36
    Make sure you use a polyurethane meant for floors.
    Polyurethane replaced shellac because it is far more durable. I don't see how it would be environmentally friendlier given the VOCs and hydrocarbons. Shellac is excreted from bugs and is dissolved into alcohol.
    Quote Originally Posted by drooplug View Post
    You've obviously never been at the business end of the bug during it's "excretion" ...
    6,116
    Yes, you need to apply a finish. Pine is a softwood and wears easily. The stain doe not protect the floor from wear. I only use OldMasters brand poly. It is easy to apply because it has very good self leveling properties and dries to a hard durable finish. You have the choice of either and oil based or a latex based poly. The latex based poly is clearer but not quite as durable the oil based will add a slight amber tint to the finish but is more durable. The self leveling properties means that it hardly shows brush marks. You should apply a minimum of 3 coats.
    6,116
    To add to your confusion, you can get poly in High Gloss, Semi Gloss, and satin finish. For a floor I refer Semi Gloss.
