    Mar 2012
    Default Crumbling Concrete under removed tile in Basement Bath
    While removing ceramic tile floor from our basement bath, that was attached directly to the concrete floor, I found a small patch of concrete between the toilet and the tub that is crumbling and sounds hollow. I'm guessing when putting the bathroom in many years ago they removed some concrete to put in the toilet drain, and replaced it poorly???? I have no experience with concrete. Anyone have any ideas on what caused this? Any solutions? Do I need to tear out all of the crumbling concrete? Thanks in advance for your help!
    6,310
    Default Re: Crumbling Concrete under removed tile in Basement Bath
    Concrete is super strong, but can't last forever. I would fix the bad parts.
    2,917
    Do you live in florida by any chance?
    Repair the concrete and tile as usual.
    Mar 2012
    No, I'm from Wisconsin.
    If part of the crumbling concrete is on the edge of the tub, does this mean I have to remove the tub to repair the concrete under the tub? All I want to do is replace tile.
    Thanks
    6,310
    Quote Originally Posted by KatherineK View Post
    Thanks
    I don't think we can recommend without seeing a photo, in your particular case.
    Many times a little project becomes a huge one very fast. That's what happens in older homes, so be prepared for the unexpected.
