Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
  1. #21
    Feb 2012
    23
    Default Re: Basement Tub to Shower conversion
    two two, moving right along.
  2. #22
    Feb 2012
    23
    Number 1, youve got mail
  3. #23
    6,075
    Here is the picture you wanted posted
  4. #24
    Feb 2012
    23
    Thank you sir!
  5. #25
    I applaud you creative persistence, but after all these postings, you need a photo that shows more and is clearer...to get a good suggestion.
  6. #26
    Feb 2012
    23
    link to additional photos.
    Thanks!!
    http://s1266.photobucket.com/albums/jj526/shoei20/
  7. #27
    These new photos are a little better.
    First, dig into the hole to verify that you have a trap. If you do, it's good.
    Then, I don't see a problem in moving the drain 1 foot, assuming that you will have the space and the slope required for smooth draining.
    Doing it right requires experience and knowledge and the job has to be inspected (by a building dept inspector). If you are not sure about how to do it, I strongly suggest to get a lic. plumber. It will be money well spent.
  8. #28
    Feb 2012
    23
    Thanks!!
    would't the trap be the 90 down, 90 up? perhaps if you have a photo or a link to a trap. i am 99% sure i have it, just want to be sure. I also have talked to a local plumber.
  9. #29
    Picture #2 shows what seems to be a trap.
    Work with your plumber and you are good to go. have him check the connections, check slope and check for leaks.
  10. #30
    One more remark:
    Where your white pvc (I think it's a 2" pipe) goes into the larger pipe: it should be sealed.
