Results 1 to 10 of 11
    Feb 2012
    Charlotte NC
    20
    Default Toilet drain size?
    I need to move a toilet drain...Just discovered that the existing drain is about a 6" diameter PVC pipe. Does it need to be this large? Once another toilet, two sinks, and two showers tie into it, it still is 6". It seems to me the toilet would need to be only 3" until it ties into everything else. Is that right?
    South*East
    1,253
    Default Re: Toilet drain size?
    Are you sure it's 6"? I have never seen 6" pipe in any home. It could be 4". You can run two toilets on 3" pipe. But it should be increased to 4" once it exits the building.
    John
    7,762
    6" may be where your main line connects with the street city sewer. Most toilets have 3" drain, like john mentioned.
    Measure again.
    Feb 2012
    Charlotte NC
    20
    Ok...I measured, and the diameter is about 4.5"...So I'm guessing that's a 4" interior diameter. That still seems a little big for a toilet. I'd like to replace it with a 3", so would that be alright?
    Feb 2012
    92
    It should be alright but it would be better to stay at 4" less chance of clogs not that 3" is not big enough I would stick with what it is there may be reasoning for why the plumber did it in 4" due to fall or some other unknown reason we cannot see.
    Ben Franklin Plumbing Of Alpine
    304 Meadowlark Dr, Alpine, UT 84004
    (801) 960-1567 ‎
    http://www.benfranklinplumbingalpine.com
    South*East
    1,253
    You can change the line to 3" but you can't reduce the line in the direction of flow.
    John
    7,762
    Before you rush to replace your 4" toilet drain with a 3" drain:
    1. What kind of floor is the toilet sitting on? concrete, raised foundation or second floor.
    2. Do you have an easy access to the drain?
    3. Why do you want to change it? do you have a leak?
    3,188
    I don't see any great advantage of reducing the size. The costs of the pipe and fittings is pretty much the same and the work is nearly identical.
    Feb 2012
    Charlotte NC
    20
    This might help to explain...my goal is to raise the 7 dropped-ceiling up to 8. The problem is that the pipes drop below joists b/c the the main drain need to run perpendicular towards back wall. I hope to re-route pipes towards window wall so they are parallel to joists. Then, I will drop them down at soffit (which will remain above cabinets, around perimeter of kitchen). When pipes are out of the way, I will raise ceiling up to normal 8 height.
    3,188
    In my fair city those 2" lines have to be introduced to the 4" line from the top with a Y fitting, you you wouldn't be able to raise that main drain unless you separated everything, which would mean a separate vent for each. More pics and less drywall please.
