    Feb 2012
    Default fiberglass tub-shower
    I have a 25 year old white fiberglass tub/shower that has yellowed, is there any way to get this unit back to white?
    7,913
    Default Re: fiberglass tub-shower
    Yes, have it refinished. Refinishing will run you between $350 and $450, which is a fraction of the cost of replacement.
    Fiberglass yellows with age as well as the clear coat finish wears out and allows soap scum and body oils to collect in the more porous resin base, causing the pan area in particular to get rather stained and unattractive.
