Thread: Crown Molding
    Feb 2012
    Arizona
    Default Crown Molding
    I am planning to install some crown molding in a friends house. All inside corners. Would it be better to cope all corners or a combination of coped and mitered?
    1,384
    Default Re: Crown Molding
    I prefer to cope inside corners unless the walls are solid paneling or cabinetry, where you can get away with miters, but copes are so much easier.
    Your initial piece will have two butt ends, and the last one with have a cope at both ends. Cut it 1/16" longer so it springs into place.
    Make a "test cope" from scrap, and hold it up in every corner along with a butt-end piece to see how your cope aligns. Mark in pencil on the walls and ceilings where the crown needs to rest to make the best joint. Follow these marks as you nail up the actual crown.
    If you back-cut your copes a bit, you can readily fine-tune them with a little sanding. For "watertight" copes, glue sandpaper to a scrap of molding, and use that as the platen to get the most perfect copes for stain-grade work.
    Casey
    1,522
    it depends, if your using paint grade i.e mdf mitres will work a bit better but you have to find the exact angle.. the problem with mdf crown is that its not very dense so the coped profile is very delicate
    if its stain grade by all means cope
