    Jan 2012
    Default undercabinet heater
    I am remoldeling a kitchen and have to remove a radiator is there a compatable heat source that can be used under the cabinet?
    Nov 2011
    boston,ma
    114
    Wink Re: undercabinet heater
    If it is a hot water radiator you can install a hot water kickspace heater with blower under a cabinet, if it is steam then you either have to move the radiator to a better location,or install an electric kickspace heater and remove the radiator.Good Luck!
