    Jan 2012
    Monticello, IL
    Default Questions about insulating basement walls
    We just bought a new house and the previous owners painted the basement walls. I want to put of polystyrene and gypsum but I wanted to make sure that the paint isnt going to cause water issues from sealing the concrete.
    Also what are the disadvantages to using expanded over extruded polystyrene?
    Default Re: Questions about insulating basement walls
    Quote Originally Posted by twiggy2cents View Post
    Not sure what you issues you are referring to -- water or condensation?
    Aside from price --- read this http://www.dyplastproducts.com/newsl...ore_xpseps.htm
    Jan 2012
    Monticello, IL
    Hmm, I found this by the same people w w w. dyplastproducts.REPLACEWITHDOTCOM/Customer_Bulletins/CUSTOMER_BULLETIN_0710.pdf
    I am guessing this one is more up to date. It seems that the biggest thing is that it is a little more permeable, which in my case will be okay because the basement stays dry and I will keep humidity under control inside the basement.
