Thread: Bathroom faucet
    Jan 2012
    Default Bathroom faucet
    I changed the washer/parts for the hot water faucet. When I turned the main valve back on, the water came directly from the faucet with the handle in the off position. To stop water flow I had to turn the main valve back off. What do I do to fix this?
    Thanks.
    6,694
    Default Re: Bathroom faucet
    Sounds like you didn't install the washer correctly or you installed a washer that doesn't fit, so it can't stop the water flow.
    To save time, money, water and aggravation replace the faucet.
    Jan 2012
    You did not mention the make of the faucet but I am a bit familiar w/ Delta's. If your faucet has a cartidge (which still require "washer" replacement) make sure you have the cartridge installed properly. You may have to do a 180 on the cartridge from the way it is in now. Look to see how the handle position effects the guts (cartridge + i/s the faucet/valve body) to see how things line up to allow water flow. Do this w/out putting it all back together first. Good luck.
    South*East
    1,217
    Quote Originally Posted by jess4INstaller View Post
    I agree that this is your problem. Good diagnoses jess. Your hired bring your lunch.
    John
    6,694
    Maybe it's not a Delta...we don't know it's a Delta or Peerless.
    South*East
    1,217
    It could be either one but in any case the fix would be the same.
    John
