    Jan 2012
    Default Need long johns on to cook
    Just bought a new slide in oven and when I turn on the burners the fan kicks on and blows air out the front (right above the oven door) which is rather quite cold. I contacted the company but apparently all stoves are now made with the vent in the front instead of the vent on the top, which my old one had. I can't believe someone else hasn't complained because it is very uncomfortable. I'm assuming that it has to draw cold air from somewhere and wondering if I put some type of insulation behind the stove itself if that would help.
    Jan 2012
    Chicago
    11
    Default Re: Need long johns on to cook
    Unless you have a hole in your wall or floor behind your stove the stove itself would not be sucking in cold air from anywhere. It sounds like its just a poor design to have the blowers pushing the air at you. Any air will feel cool when is pushed thru a fan at you. Does the air remain cold even after using the oven for a while?
